Mathcad Prime is significantly hampered by not being able to display a matrix as a picture. The PICTURE operator in Mathcad 15 enabled this and would be an important improvement to Prime.
Will do. The issue I have with the ideas section is that instead of developing new ideas, all that we want is Prime to be as functional as M15 and then we can move forward.
