The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Allow array-indexed variables
0 Kudos
Please consider allowing MathCAD Prime the access of array-indexed
variables within a Given-Find solver block.
Sincerely,
Julio C. Banks, BSMET, MSME, PE & CGC
President
J. C. Banks Construction, LLC
Port Saint Lucie, FL
5 Comments
MikeArmstrong
Can you provide an example?
Mike
JCBanks
11-Garnet
Attached is the file with array-index.
This file has a counterpart having
literal indeces.
Sincerely,
Julio C. Banks, P.E.
BanksJ@asme.org
VladimirN
24-Ruby II
Hello!
So you have solved this problem by using variables from an array by replacing variables with literal indices (in block Given-Find)?
JCBanks
11-Garnet
Yes.
The PDF-sample I provided is indeed the one with array-indexed variable.
The sequence of development is as follows:
1. File ran with literal subscript
2. Newer version allowed array-index variable
3. The array-indexed variable feature was removed
4. Had to go back to step 1 🙂
Am I in the correct forum?
All I am seeking is for PTC to consider allowing the use
of array-indexed variables with block-solver !
Please advise,
Julio Cesar Banks
BanksJ@asme.org
olivierlp
Community Manager
Status changed to: Archived
