I am focusing to perform Belt Conveyor Systems calculations (in depth) using Mathcad Prime versions. After some preliminary work, I did the first of a few hundreds of design calculation files. Despite, this is the first (and comparatively simple), the performance of the work sheet is too slow. As such, I am thinking how I will be able to keep building the whole system of design files.
I look forward to receiving comments.
Note: the file (Mathcad Prime 2.0) attached.
