Change Grid Size without having to reformat Pages
Please reprogram grid sizing so that the grid changes do not reformat the page. At present, grid size changes cause the worksheet to either spread out or compress, either way making the document unreadable in standard format.  Thanks.
RantEng - a community member provided a work-around. See at: https://community.ptc.com/t5/PTC-Mathcad-Ideas/Change-Grid-Size-without-having-to-reformat-Pages/idi...
1 Comment
amcgough
Status changed to: Under Consideration
Hi there,
Currently, the grid change size behavior is designed to make sure calculation order is maintained - the priority here is to make sure regions don't move out of order. However, the current behavior does have some limitations, and we do want to make it easier to switch between the two grids and not have to pick one and stick with it from that point on. The linked workaround is useful, but we do want to change what we currently have to make sure we maintain calculation order without impacting the content layout.
Andy.
