1)I would like to see complex number handling directly both in cartesian and polar coordinates. To be able to choose what system do you want the results shown, as if it were a unit.
2) I do not know it would be possible but in electrical engineering, we have apparent power, real power and reactive power all with different units. Could mathcad detect if a result is complex, then use apparent power units (VA, kVA, MVA), when the result is the imaginary part of a complex number reactive power units (var, kvar, Mvar). And if it is the real part, active power (W, kW, MW).
