The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Data and File Export in Mathcad Prime 8.0
0 Kudos
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
I am an engineer in the development department of a medical product manufacturer
2. What version of Mathcad are you currently running?
Mathcad Prime 8.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
I often need data series, which I previously created in Mathcad15 as section-wise defined functions. In general, these are functions in the form F(X)=.......... with X=0,(1/N)......n, N=1023 (number of data rows) and n (any value from the physical boundary conditions).
The variables, as well as the function values, usually occur as fractional rational numbers. Up to now in Mathcad 15, there was the possibility to export a data series directly with the function "right mouse button" and "export" as CSV file. It did not matter in which numerical form the data was available.
This simple but efficient method to export data from a Mathcad Prime File does not exist (yet). Here it is mandatory to define the function via a matrix and to use e.g. the function "WRITECSV". In addition, the matrix definition does not accept fractional number formats, so that the data series must be redefined yet another time.
All in all an unsatisfactory way to export a data series quickly.
But maybe there will be an improvement soon in a patch or in a next version of Mathcad Prime.
Best wishes
Ralf
Häufig benötige ich Datenreihen, welche ich bisher in Mathcad15 als abschnittweise definierte Funktionen erstellt habe. Es handelt sich im Allgemeinen und Funktionen in der Form F(X)=.......... mit X=0,(1/N)......n, N=1023 (Anzahl Datenzeilen) und n (beliebiger Wert aus den physikalischen Randbedingungen)
Die Variablen, wie auch die Funktionswerte treten üblicherweise als gebrochen rationale Zahlen auf. Bisher im Mathcad 15, bestand die Möglichkeit eine Datenreihe direkt mit der Funktion "rechte Maustaste" und "exportieren" als CSV-Datei zu exportieren. Dabei spielte es keine Rolle in welcher Zahlenform die Daten vorliegen.
Diese einfache aber effiziente Methode Daten aus einem Mathcad Prime File zu exportieren existiert leider (noch) nicht. Hier ist es zwingend erforderlich die Funktion über eine Matrize zu definieren und z.B. die Funktion "WRITECSV" zu verwenden. Darüber hinaus akzeptiert die Matrizendefiniton keine gebrochenen Zahlenformate, so dass die Datenreihen noch ein weiteres mal umdefiniert werden müssen.
Alles in allem ein unbefriedigender Weg um eine Datenreihe schnell zu exportieren können.
Aber vieleicht gibt es hier ja bald eine Verbesserung in einem Patch oder in einer Folgeversion vom Mathcad Prime.
Beste Wünsche
Ralf
4. What is the use case for your organization?
Export data series for servo application
5. What business value would your suggestion represent for your organization?
It is not possible to make a simple statement here, but there is certainly a considerable saving in time and therefore also in costs.
1 Comment
olivierlp
Community Manager
Thank you @RalfSprick for your idea (in 2 languages! 🙂 and welcome to the PTC Community. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
