Deleting Areas, Dragging into Areas
0 Kudos
It is a shame that you cannot delete an Area without losing its contents - as was available in MC15. In Prime7 if you regret creating an Area you have to be careful to CTL-X everything out - then insert enough blank space to ensure that the pasting does not entangle with other parts of the worksheet.
You cannot drag expressions into an Area if you want to move its boundary. You have to cut and paste - with the same problem of ensuring the pasted parts do not overlap existing parts.
1 Comment
GeoffD
Conversely, you cannot drag stuff out of an Area back into the main owrksheet.
