Display Hex numbers
Display Hex numbers
This isn't a new idea, many previous versions (pre-prime) could do it.
Display equation results in Hex or Binary. Even entering values as hex or binary.
Mix and match in the same equation.
3 Comments
mzeftel
1-Newbie
David,
Can you provide some examples of where you'd want to mix hex and binary in the same equation?
Mona
athurin
Even better than Hex number, a whole "programming" environment that could take into account the number format (signed/unsigned integer/float, 8/16/32/64 bits...), with operations like left and right shift, bit-wise and/or/not, etc, could be a fantastic tool. Especially if it can mix with "normal" type of variables.
olivierlp
Community Manager
Status changed to: Archived
