The current animation is limited to 0...999 (i.e. 1000) FRAMEs. This is a limitation on simulations that is no longer warranted, and it is difficult to create animations of longer sequences easily.
While not common I am now needing simulations that extend well beyond 1000 frames. In my case is is a video of sweep angles for a gimballed TV sensor, and I need to show where oscurations occur.
Simply extending the allowed FRAME limit in the dialog box would solev the problem.
This is for V15 M030 and later.
