In M15 it is possible to have 10 different Font tags (Math Style) för Math expressions and define 7 own namnes
In Prime 3.1 the are only 6 Math Font and no user font.
This couse a problem when converting M15 documents to Prime. I use diffetent font tags for matix and vectors and this gives mi possibility to have the same name for variables and vectors.
Is it any way to create own Math Formats in Prime 3.1? If not will it be possible i Prime4?
