Ability to type in an equation as a legend.
At the very least full text support in legends including superscript and subscripts
Sheet support like in excel. Ability to share variables between sheets.
Use case. Photovoltaic-Battery-Generator Design
Sheet 1: Solar position calculator : Independent sheet
Sheet 2: Solar irradiation estimation incorporating local climate. Depends on Sheet 1
Sheet 3: Load estimation : Independent Sheet
Sheet 4: Photovoltaic Panel Simulation and Design: Depends on Sheet 2
Sheet 5: Battery charging/ discharging simulation and design : Independent sheet
Sheet 6: Diesel generator load simulation and design: Independent sheet
Sheet 7: Tie all of them together for a complete Hybrid system: Depends on sheet 4,5, and 6
