Inputs to Table & Matrix
0 Kudos
Is there a posibility to use copy and paste in matrix and tables, insteade of inputting the data manually specilally if we have a big number of inputs!!!!!!
13 Comments
MikeArmstrong
You can copy the data from a Matrix and paste it to another variable or you can define a variable as the data.
Can you provide an example of exactly what your after.
Mike
VladimirN
24-Ruby II
Please provide an example. I recommend to you using a built-in function "READ..." to read the files that contain the necessary data.
HarveyHensley
3-Visitor
Hinndnaser,
I was waiting for you to provide more information on what you are trying to do, but since you haven't here's my suggestion. If you have data in Excel, then your can copy the matrix as if you were going to paste it somewhere in Excel. Then, in Mathcad, create the matrix name, ; e.g. X:= and paste (cntr-V) in the cursor where a value or formula would be input. The matrix is created.
MikeArmstrong
What's wrong with calling Excel data from Mathcad?
Mike
VladimirN
24-Ruby II
Mike
Agree.
HarveyHensley
3-Visitor
Mike
Nothing, except Hinndnaser asked for a way to cut and paste to create a matrix.
h_nas
Cutting the middle man, I don,t want to joggle with three programs, I want to be Excel free user!!
HarveyHensley
3-Visitor
You've never said in what the program that the data you want to copy is produced. Regardless, I would try the control-c in the table in that program and control-v in Mathcad as I explained with Excel as the source. It may work.
MikeArmstrong
Fair enough, but I would have to state that I feel copying and pasting in that way is poor way of dealing with Matrices.
Mike
MikeArmstrong
Please provide a worksheet and detail exactly what you are after. This is the 10th reply to this thread and it's going no where.
Mike
joshuanknight
1-Newbie
Hello, Harvey, I am trying to do a simple copy and paste from Excel to Prime 2.0. When I hit Ctrl-V or Paste on the menu, nothing is printed. If I paste 1 value it works fine, but I need to copy a 1x440 matrix. Is it Prime 2.0 that is the problem? Thank you!
24-Ruby V
In Mathcad 15 you would have to type M: and then Ctrl-V and you assign the variable M a Matrix that way.
In Prime2 this does not work that way.
In Prime2 simply click on an empty space and type ctrl-V. One of those new tables is inserted and you have to fill in the headers. Unfortunately you don't get a normal matrix that way.
olivierlp
Community Manager
Status changed to: Archived
