Inserting pictures in MathCAD 15
Hello.
I am working on a template for bolt calculations and I have this idea of displaying an image of the chosen threaded fastener next to my selection. I presume this would involve some sort of code to be written to tell MathCAD which picture to display. I intend to use radio buttons to indicate my selection, but I don't understand how I can display different pictures, based upon the output value of the radiobutton group.
Anyone...?
5 Comments
h_nas
This is a good idea, but I am not sure if it is doable!!!!
MikeArmstrong
Try searching through Richards Extra components worksheet. You could create a file path which is dependant on the radio but and then use a scripted component to open the image.
Mike
RichardJ
Insert a picture viewer ("Insert", "Picture"). Put the filename of the selected inmage in the placeholder.
ptc-4089697
1-Newbie
Thank you Mike and Richard.
I added a separat output variable into the Radiobutton group which had the respective path and filename of the picture I wanted to display next to the selection. Then it was easy enough to add a picture dialog and insert the output argument from the radiobutton group as the input variable for the picture. Seems so simple now....
Big thanks.
Helgi.
olivierlp
Community Manager
Status changed to: Archived
