Allow macro enabled embedded spreadsheets. I frequently use spreadsheets within my Mathcad document to handle the things that spreadsheets handle very well. Sometimes I use user defined functions within a spreadsheet. These are not allowed because Mathcad does not support an xlsm format. If you create a function or macro, it is not saved when you close the spreadsheet.
