Make the Float keyword work with the explicit modifier. Presently, Float overrides the explicit modifier and returns a result with a single numeric value. I frequently use "Explicit, ALL" to show actual values substituted into an equation. "Explicit, ALL" shows all numbers to 15 decimal places. Using Float returns a single number.
