I use Mathcad to present ideas in physics and mechanical engineering. In school I was taught to use vector notation (arrow over variable) to differentiate it from scalars. Leaving this off would lower my grade. The notation makes it easier to follow the derivation or calculation. I propose adding vector notation to the symbols library to make the formulas correct.
