Hello. Recently I started using PRIME(4.0) and noticed the following.
The shortcut key of entering subscript has changed from period(".") in M to "Ctrl+ -" in PRIME.
I use this shortcut key very often. So very bad usability in PRIME.
I request to improve this expression.There are two suggestions..
- back to the MATHCAD15 shortcut key
- able to customize the shortcut key
