Program with 10 internal loops takes for ever to returen the result.
0 Kudos
I am writing a program with about 10 internal loops, and its not returning any results, but the counter is still running, I tried to simplify it, still running while I am typing at this moment.
any advise!
14 Comments
RichardJ
Do you mean loops nested 10 deep?
Please post the program.
h_nas
Yes, they are 10 loops, one inside the other. I tried to simplify them, still take time, any advise in how to shorten the time!!
RichardJ
Can you post the worksheet?
ValeryOchkov
Can I post?
There was an old task USA+USSR=PEACE
We can try to solve this task by using 7 nested for-loops: for U, for S, for A, for R, for E, for C, for E
But we can simplify (by a mind help) this task and have only 3 nested for-loops - for A, for C and for S:
http://twt.mpei.ac.ru/ochkov/mc8Pro.book/6_text.files/6_06.jpg
This program gives us 4 solutions (решение) but only first is correct: 932+9338=10270.
Try please solve this (modern) problem USA+IRAN=PEACE
Both tasks are a good example of a combination of own mind and a computer!
VladimirN
24-Ruby II
Please attach your Mathcad worksheet to the message.
MichaelH
1-Newbie
Try using the trace() or pause() functions at strategic points in the loop and run in debug mode.
Use the help resource for details on how to implement them.
ValeryOchkov
http://twt.mpei.ac.ru/ochkov/Mathcad_12/6_24b_Trace_in_MC13.gif
ptc-4853592
1-Newbie
Hi Valery,
Could you possibly upload the Mathcad 15 version of the Root Newton file you have posted a picture of - and perhaps you could explain to me how you put the squiggly = sign (the approximate sign) - in the program loop - since I thought you could only use Boolean operators in the programming?
Look forward to hearing from you.
Kind regards,
Gordon.
ValeryOchkov
I hope the picture help you:
ptc-4853592
1-Newbie
Hi Valery,
Your foot note below the picture explains why I couldn't see this in Mathcad 15
I haven't moved onto Mathcad Prime yet.
Many thanks,
Gordon.
24-Ruby V
Thats a misunderstanding - its not Prime. On contrary, the whole trick works in Mathcad 15 (and below) only, as Prime is too much limited - there is no choice for infix function evaluation available there AFAIK.
The approximate sign is simply the name of a user defined function which is then used the infix way - you can copy and paste that character from anywhere. One way to do it without any external character map is to go to Help/Quicksheets/ExtraMathSymbols and copy it from there. Everytime you use that newly created function you will have to do some kind of copy and paste action again.
ValeryOchkov
It is user defined operator.
In Mathcad Prime Minister it is a built-in operator:
ptc-4853592
1-Newbie
Hi Werner,
Thanks for showing me something else I didn't know about Mathcad. It would be good if some of you Mathcad experts got together to write a book on the things you just don't see in Mathcad books or on the Mathcad training courses.
Thanks again,
Gordon.
olivierlp
Community Manager
Status changed to: Archived
