Provide equation numbering for mathcad expressions, whether numeric evaluations, symbolic evaluations, or simple expressions such as booleans within a Given-Find block.
The numbering should allow auto numbering for at least two levels and an alpha, e.g. 10.1a. And allow standard prefix/suffixes such as "Eqn (" and ")" so the result would be "Eqn (10.1a)".
The equation numbering would be in a placeholder subsequent to the current units/dimension.
Probably enable by a properties tick box, wich would also cover the "restart numbering" for the sub levels, (and separator characters if needed)
Should the Table of Contents ideas be implemented then obviously the equations list should also be available.
