Well, one obvious one is that restitution of the equation right-click context menu. The context menu now only exists when the object is selected, but not during edit mode. Moreover, the new context menu is severely limited, drastically reducing one's productivity during edit mode. EVERYTHING now needs to be done from the ribbon bar.
TTFN
