Solve Block should support symbolic constraints defined as variables outside the block
0 Kudos
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Electronics. Design. R&D
2. What version of Mathcad are you currently running?
Prime 8.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
I would like to assign a constraint as a symbolic evaluation to a variable and use it inside a Solve Block, but this is not supported.
Instead, I have to define a function of the variables and then set the constraint in the block.
or
4. What is the use case for your organization?
Improve readability
5. What business value would your suggestion represent for your organization?
Producitivity
1 Comment
olivierlp
Community Manager
Thank you @LJ_10477198 for your idea. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
