Since Mathcad cannot push dimensions into family tables, it doesn’t really help us. Can you build the capability into future versions of Mathcad so it will work with family tables in Creo? It would also help a ton to be able to drag and drop calculations like in excel. In excel, it is very efficient to calculate the required wall thickness for a family of cylinders with 5 different bore sizes for example and drive the Creo family table.
