Table of contents based on headings
0 Kudos
Table of content based on Headings in the workbook
Similar to how programming IDE keep track of functions, allowing you to jump to that function with a single click.
5 Comments
MikeArmstrong
This can be done, but requires the use of a scripted component.
Mike
MikeArmstrong
Have a look at the attached.
Mike
MySchizoBuddy
1-Newbie
I'm going to use this. Thank you
I was however talking about an alternate method.
Look at he link below
http://www.flickr.com/photos/26717404@N00/62316794/sizes/z/
On the lower right hand side you see text "Newton Polygon blah blah". that is navigation for different sections in the document.
MikeArmstrong
Oh I see. Like you usually get in *.pdf documents.
This can also be done. When I had a copy of RAWK, I could select a topic and access that section automatically. Not quite sure how it worked though.
Mike
olivierlp
Community Manager
Status changed to: Archived
