While the table features within Mathcad Prime 1.0 are a big step forward, allowing multi unit variables to be defined. I believe the tables could be improved without much change. Below below for an example of what currently is available.
Even allows a mulit length table, very impressed.
But I would also like the table to accept predefined/calculated variables. So if x and z in this example had been calculated above, I could select insert table, select two inputs and choose the variable and unit to go in the table and have Mathcad automatically display the number of elements.
Has anyone got any thoughts?
Mike
