Text comments, subroutines, better word processing and graphics
0 Kudos
  1. In Programming within MCAD I'd like:
    1. the ability to add Text Comments in subroutines
    2. a simple way to add your own subroutines into the function library (or even better a separate user defined set of libraries)
  2. Better Word Processing capabiities
  3. Graphics
    1. Publication quality 2D graphics as an option
    2. Simpler user defined scales & ranges in 3D plots
    3. Beter Labelling on Plots
      1. User defined fonts
      2. Greek letters
      3. subscripts and superscripts included
      4. saving graph as a jpeg file through simple click and file
9 Comments
MikeArmstrong
  • a simple way to add your own subroutines into the function library (or even better a separate user defined set of libraries)
Can we not do this and place the pre-defined functions in collapsed areas?
Mike
Efried
1-Newbie
I'm using format("Comments") for commenting but may be that brough me into that unit troubles, who knows...
RichardJ
Using the format function does not achieve anything, but it does no harm. If it's not assigned to a local variable the function is not even executed. If it is assigned to a local variable then it just returns your comment string. But you could just put the sting "Comments" in on it's own.
MikeArmstrong
Can we not do this?????
    1. Beter Labelling on Plots
Do you mean change the font on a graph?
      1. saving graph as a jpeg file through simple click and file
A nice workaround is to copy and paste the graph into IrfanView, which is a free download.
Mike
ValeryOchkov
I use string constants as comments in subroutines - see one example:
http://twt.mpei.ac.ru/ochkov/Mathcad_12/6_25_Local_Func.png
Efried
1-Newbie
Please, please tell me how you managed having the negative indent to the left side in your second line !
thanks a lot!
MikeArmstrong
Isn't Valerys image showing different function, not a negative indent?
Mike
ValeryOchkov
Sorry, it is only picture from my book - not real worksheet. I have edited this picture (made the negative indent) for the save space in the book
My readers know it from from preface.
Only Mathcad MM can do it - see http://communities.ptc.com/message/153976
olivierlp
Community Manager
Status changed to: Archived
