I use embedded worksheets in Creo models, and when I output values from the model back to the sheet they are ALWAYS in METERS because this is the base (default) unit for MathCAD. We are constantly having to show the value in M then convert to the model units.
Please allow us to output values in the model units back to the sheets so I don't have to see 0.0003 M etc on small plastic parts.
