Using Mathcad 15 I would often tile multiple documents to either cut and paste between them or compare different versions of a worksheet. In Mathcad Prime this functionality has been removed and two versions of the software have to be open to achieve the same effect. The later method is usable but its an additional step and feels like a step backwards.
