If I have an expression that contains some algebra or even a single variable that I would like to paste into another expression the process is a bit cumbersome. Often (but not always) a simple copy-and-paste does not work. The workaround is to copy the part desired into a blank part of the worksheet and then copy and paste it into the target expression.
