I was taught that the first step in solving a Physics or engineering problem is to create a sketch. The sketch ensures consistent variables and proper coordinate system directions. Having to create this in an outside application makes the solution process in Mathcad Prime disjointed. Revisions to the sketch are inevitably necessary and a distraction to the process if done outside the program.
