The ability of Prime 8 to consistently evaluate the matchNaN function is a bit patchy - see below - this often happens where it doesn't find the NaN's in a file first go.
Also, I support an earlier (now archived post) that the failure to find a NaN resulting in an error condition could be improved e.g. to return a result that could be improved by returning a result that subsequent computations could use?
