"Remove Space" Keyboard Short Cut
0 Kudos
The process of converting MC15 to Prime has massively improved - however, you still end up with a lot of blank space to clear from the converted document - could we please have a keyboard shortcut to avoid having to cycle through "Document>Remove-Space>drop-down menu>Empty Space"?
With many documents to polish after conversion, this would speed things up, improve user experience and avoid accidentally deleting stuff by rapid delete, delete, delete, etc. when you get tired of going to the menu ribbon.
2 Comments
DJNewman
Hi Geoff,
DJNewman_0-1638295430754.png->
DJNewman_1-1638295455045.png->
I know it's not a keyboard shortcut, but right-click to empty space is at least currently faster than going to Remove Space from the ribbon, right?
And you're probably using your mouse to move the cursor to the space anyway.
GeoffD
@DJNewman Many thanks for the info ! - this certainly reduces the effort in tidying up!
Unfortunately, the right-click move isn't available within solve-blocks which, on conversion, can get a bit spaced by all the ":= "expressions getting shunted up page. However. for me, the greater part of tidying up solve-blocks has been to re-establish a logical flow of explanatory text and equations amongst the lines ejected from the MC15 solve-blocks now they have been separated from their constraints.
Thanks again for your reply.
