Thanks for your support!
I`ll try that - at first I will need to get access to the license management section of the website. So I will have to get in contact with the customer care service.
Best regards!
Anmerkung: Es handelt sich um Mathcad 14
Mathcad 14 is no longer supported but you can try:
ipconfig/all to find the Physical Address for your Local Area Connection.
Best regards!
