We’re aware that the eSupport site is currently down, preventing community login. Our team is actively working on a fix and we’ll share updates as soon as possible.
The Version is prime 10.0.1.0.
However, I've just installed it this morning, and the process was exactly the same as last time, but this time there were no more errors and it was completed smoothly.
See if the solution to your problem can be found here: https://community.ptc.com/t5/Mathcad-Installation/All-About-Mathcad-Software-Installation/m-p/706433#M26
The installation process has been stuck on this page and will not continue. Then, nothing has happened.
What version of the program are you trying to install?
