安装过程会在第三步莫名其妙的停止,无法选择安装的产品。
勇张_13119710
The installation process will inexplicably stop in the third step, making it impossible to select the product to be installed.
The Version is prime 10.0.1.0.
However, I've just installed it this morning, and the process was exactly the same as last time, but this time there were no more errors and it was completed smoothly.
5 REPLIES 5
See if the solution to your problem can be found here: https://community.ptc.com/t5/Mathcad-Installation/All-About-Mathcad-Software-Installation/m-p/706433#M26
The installation process has been stuck on this page and will not continue. Then, nothing has happened.
What version of the program are you trying to install?
