Hi @PR_9907922,
This is working correctly as per product specification for PTC flex-enabled applications
If node-lock license is configured, PTC flex-enabled application cannot be accessed via Remote Desktop session or Terminal Services connection
Physical access to the station is mandatory to enable successful startup of Creo Parametric when using a Locked license file
Vipul
Hi @PR_9907922,
Vipul
