Configure License Mathcad Prime 9.0.0.0 Trial
LA_2958193
7-Bedrock
I am trying to configure the Trial license version for Mathcad Prime 9, this is the error message I get when I try to configure using the file I received via email:
Failed to configure license for PTC Mathcad Prime 9.0.0.0: Access to the path 'C:\ProgramData\PTC\Mathcad Prime\MathcadPrime.exe.V7.config' is denied.
I installed the trial on another laptop, and it works.
Luis Aponte
5 REPLIES 5
LA_2958193
7-Bedrock
(To:ppal)
Luis Aponte
Did you install the program in the default path?
Luis Aponte
LucMeekes
(To:LA_2958193)
Chances are that if you simply delete the file
You are then able to use Prime 9.
(Prime will create the file when it is absent.)
