Conversion From 15 to Prime 7 Failed
MO_10010840
3-Newcomer
I am still in the process for which version of mathcad to go with. I was wondering if you would be able to help me out. I did a conversion from Mathcad 15 to Prime 7 but it seems that it converted the table in 15 to a matrix and now none of the equations work anymore. Is this something you can help me with?
Please find my solution in the attachment. I used an external text file as raw data table. You only need to change the path to this text file.
Can you attach both worksheets?
VladimirN, see below for attached. Is there a way to get the converter to keep the table in table form instead of transforming it into a matrix? I have not purchased a license yet and am debating trying to extend my time with Mathcad 15 for a few years.
Thank you for your quick reply.
VladimirN, thank you for your help!
You're welcome.
