Please find my solution in the attachment. I used an external text file as raw data table. You only need to change the path to this text file.
Can you attach both worksheets?
VladimirN, see below for attached. Is there a way to get the converter to keep the table in table form instead of transforming it into a matrix? I have not purchased a license yet and am debating trying to extend my time with Mathcad 15 for a few years.
Thank you for your quick reply.
VladimirN, thank you for your help!
You're welcome.
