Hi RO_10893973,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution for the benefit of other members who may have the same question.
Of course, if you have more to share on your issue, please let the Community know.
Dhiraj
Those are known 'defects' in MathCAD Prime!
You cannot purchase any MathCAD version or MathCAD Prime prior to 7 due to licensing agreemente between PTC and third-party code used in those versions.
While you cannot purchase Mathcad 15 at this time because we end-of-saled it at the end of 2021, for more information, read this:
As for conversion, there are two options.
Number one, those control objects now function as combo boxes, as shown in this new video. You can accept Mathcad Prime's combo box functionality for these controls.
https://www.youtube.com/watch?v=VPcdwbJrJyI
Number two, control objects are an area of focus for the upcoming Mathcad Prime 10; once that releases and you upgrade to it, it is likely that the control fidelity will be much more similar to how you saw it in Mathcad 15.
Hi RO_10893973,
Dhiraj
