Conversion of a file with .xmcd extension
ML_10426113
2-Guest
Hi all,
I downloaded the Mathcad trial version and I am trying to import a file with extension .xmcd, but the conversione function doesn,t work. Please can you help me?
Starting from the 7th version of Mathcad Prime you can use the built-in converter (before the installation process, it is necessary to select it among the installation components).
thank you for your answer, but I have already installed the tool XMCD, MCD converter, but it doesn't work with the file that I need to convert..
I think that the problem is the file itself.
You can download the file at the following link, if you want to try the conversion:
https://www.onsemi.com/pub/collateral/fan7688-and-ncp4390-loop-gain-transfer-function-calculator.xmcd
Many thanks,
Matteo
You need to open all hidden/password protected areas in your worksheet..
