Thank you.
I'm using the full functional trial version of Prime 9
The document that shows the process for earlier versions of Mathcad is here, starting from Slide 53: https://www.foundationperformance.org/pastpresentations/ClarkPresSlides13August14.pdf
The data I want to plot contours from is in the attached file. I'll post in your suggested thread, thanks.
Murat
Your question shows up here (https://community.ptc.com/t5/Mathcad-Installation/Draw-contour-from-scattered-x-y-z-data-points-topography/m-p/912587#M3432 ), in the forum part dedicate to installation problems.
For a better audience, you should post you question here:
https://community.ptc.com/t5/Mathcad/bd-p/PTCMathcad
Preferably attach your Prime (.mcdx) file, with any attempt you made to get what you want.
State which version of Prime you are using.
Your reference ("a process is described here") did not come across, so there's no clue as to what Slide 53 you want to show.
Thank you.
Murat
