After contacting my company IT support they thought that the issue was with conflicting offline files however the issue was with the registry files within the MathCAD software, after adding a new registry the issue has stopped.
What happened between the last time you saved the file and this time to open it again?
Did you immediately shut down the PC after saving the file? Then shutting the PC may have interfered with saving the file...
If the file size is actually 0 kB, then there is no data in it. That means there is nothing to recover.
One possible way to (partly) recover is to check your backup, that is: the backup you have made from the data on your computer.
Another method of recovery is that you re-create the sheet...
Please specify which version of the program you are using.
Glad you solved your problem.
