Error "Conversion Failed, Conversion aborted.." while converting legacy Mathcad worksheet to Prime
Harry_Seth
Issue:
  • Error Conversion Failed, Conversion aborted.. while trying to convert any legacy Mathcad worksheet
  • Getting error Conversion Failed, Conversion aborted.. while trying to convert Mathcad worksheet
  • Converter crashes
Cause:
  • In-complete or issues with Mathcad Prime installation
  • Converter not registered with Windows
Resolution:
  • Uninstall and Re-install Mathcad Prime
  • Run the setup.exe using Right Mouse Button Option "Run as administrator" on Windows 7, Windows 8 and Windows 10 machines
LucMeekes
(To:Harry_Seth)
You can add another potential cause:
The filename contains a character that the converter doesn't like, such as '#'....
(See https://community.ptc.com/t5/Mathcad/Error-Converting-file-from-version-15-to-Prime-8/m-p/857766#M205277 )
Hi LucMeekes,
Yes, you are correct; I will have this message passed to our technical team and have the article updated.
Thanks for your input
Anurag
LucMeekes
(To:anursingh)
Better still, your technical team makes sure that file name characters accepted by Windows do NOT cause (such silly, unnecessary) errors in Prime and/or its converter.
(To:LucMeekes)
Its the converter only. Prime will read and write files containing a hash (#) without troubles.
The converter also has no problem reading the legacy file with the hash in its name - the error occurs when the converter tries to create the converted file.
And I fully agree that this is a bug which should be fixed rather than just being documented 😉
