Import mcd to prime 6
CA_9541895
2-Explorer
I am using Mathcad Prime 6.0 6.0.0.0
how to do i bring in .mcd into 6?
Hi @CA_9541895,
Mathcad 15 supports native formats *.xmcd, *.xmcdz, *.mcd (Worksheet) cannot be opened directly in Mathcad Prime
XMCD MCDX converter can be used to convert legacy files. To enable XMCD MCDX converter Mathcad 15 is necessary to be installed on the same machine up to Mathcad Prime 6
Wherein PTC Mathcad Prime 7.0.0.0 provides a standalone legacy worksheet converter that can be installed alongside the application and does not require any legacy version of Mathcad 15 to be installed to use the converter.
Vipul
4 REPLIES 4
You need to convert the file to the Prime format.
Cheers
Terry
Hi @CA_9541895,
Vipul
CA_9541895
2-Explorer
(To:VipulT)
Great thanks for the help
carlos
Do you have a lot of worksheets from legacy versions of PTC Mathcad, like Mathcad 15 (.mcd/.xmcd files), and need to convert them into PTC Mathcad Prime worksheets (.mcdx files)? This video shows you how to convert your files, including in batches, using Mathcad Prime's converter tool, and ...
