Is it possible to obtain the installer and license file on a PC that can connect to the Internet, store them on a storage medium such as a DVD, and then move them to an offline PC (a PC that cannot connect to the Internet) and install them there?
If there is a way to prepare something on a PC that can connect to the Internet and install it on another offline PC, please let me know the details.
(Are there any functional restrictions in that case?)
Translated text from Japanese to English using Google translate
Subject: mathcadのインストールはオフラインで可能か
Body:- インターネットにつなぐことができるPCでインストーラやライセンスファイルなどを取得し
それらをDVDなどの記憶媒体に格納し、オフラインのPC(インターネットにつなぐことのできないPC)へ
移動しインストールすることは可能でしょうか。
インターネットにつなぐことができるPCで何かしら準備をして、オフラインの別PCへインストールする手段があれば詳細をご教示ください。
(その際、機能制限などはないでしょうか。)
- By community moderation team.
Get in touch with PTC sales representative: https://www.ptc.com/en/contact-us
Hello @勇平_11028301,
Thank you for your question.
Your question appears to be well documented, however I'd like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
Hello @勇平_11028301,
It looks like you have a response from a community member. Please follow as suggested by the community member and contact a PTC Sales representative.
There after if you get answer to your question, please document it in this topic and mark it as accepted solution. It will surely help other users who may have a similar question.
