I just resolved the issue by installing the latest version of the license server. With Lmadmin 11.19.1.0 everything seems to work out of the box.
Thanks and best regards
It looks like your license file only contains additional licensed features (Extension Packs).
Hi VladimirN,
thanks for your response. Unfortunately, this is not the case and does not explain the behaviour. The features we have licenses for are the following:
#FeatureName Qty Product Release Type
#254 250 Mathcad Image Processing Prime 6.0 Flt Opt
#255 250 Mathcad Data Analysis Prime 6.0 Flt Opt
#256 250 Mathcad Signal Processing Prime 6.0 Flt Opt
#257 250 Mathcad Wavelets Prime 6.0 Flt Opt
#MATHCAD 250 Academic Mathcad Term License Prime 6.0 Flt Lic
#MathcadPrime 250 Academic Mathcad Term License Prime 9.0 Flt Lic
The LMTools version we are using is 11.13.1.3.
I recommend opening a new Case for technical support:
FYI ... if you read the page no.3
in https://www.ptc.com/support/-/media/support/refdocs/Creo_Parametric/compatibility/PTC_LMS_Download.pdf?sc_lang=en document,
then you will find that the PTC_E daemon is intended for Codebeamer, PTC Arbortext Content Delivery, PTC iWarranty, PTC MOVE applications.
