You should request for a license manually by providing your Mathcad product code and physical address of Ethernet adapter using the following web case logger: http://support.ptc.com/support/mathcad_supportCenterSingleUser.htm
The license file will be sent via E-mail.
Hi @DA_11714075,
Anurag
