Please share snapshot of your license file. Also, perform below steps on your machine:
1. Open Command Prompt (search for it in Start Menu)
2. Type command cd "C:\" and hit enter.
3. On the new line, type ipconfig /all >IPConfig.txt and hit enter.
4. Share the file IPConfig.txt which you would find created under C drive.
Based on above information, we can confirm whether the license file is generated for the correct host Id.
What does your license file contain? Show screenshots of its contents.
