I've started the installation process for MathCAD Express, but when I reach the "Application Selection" step there are no applications to choose from. I'm not sure how to correct this issue.
Hi @GBrew,
Refer the below link for for step by step procedure to download the trial/express version
How and from Where to Download Mathcad PrimeTrial or Express Edition?
Vipul
Having the same issue, the reply didn't help as this was were i got MathCAD from in the first place.
I just asked a friend if he could try to install it on his PC, same issue, i suspect that the install package that is downloadable doesn't include the mathCAD file.
I tried to download Mathcad again, but this time I opened the installer as an 'Administrator'.
Believe it or not, I had a list of applications to choose from. It's installing now.
If you are still having issues try opening the installer as an administrator.
Hopefully that work for you also.
