Mathcad Prime 6/7/9 not launching after initial splash screen, instructions in
Solved: Mathcad Prime 4.0 doesn't start anymore. - PTC Community
Mathcad Prime does not launch after the initial sp... - PTC Community
Does not help, everything on there has been tried.
We have the newest W11 enterprise editions with latest updates, software has been tried to run with admin rights as well local/domain admin accounts.
No logs have been recorded in programdata and config files are almost empty before/after deleting .conf
"<?xml version="1.0" encoding="utf-8"?>
<configuration>
<userSettings>
<Spirit.Properties.Settings>
<setting name="UpgradeSettings" serializeAs="String">
<value>False</value>
</setting>
</Spirit.Properties.Settings>
</userSettings>
</configuration>"
Does anyone have any idea what could cause this problem?
Thanks dearly,
Tom
I recommend you open a new Case here - "Open a Support Case": https://support.ptc.com/apps/cs_loggers/case_logger/auth/ssl/log
Thank you, but it still the only option is opening a thread in here.
Issue is still alive, nothing has worked so far.
